Any clues on how to attach pictures to a post?
After you write your message and you scroll to the bottom of the screen... right above the send button is a small box that says attachment. Click on
the browse button , find the location of the file that you want to attach, hit OK then you are back to the original screen. Press send and you should
be fine, so long as the file falls within the size parameters of the BBS software. Easy 1,2,3!
Thanks for that have posted pictures on 'fastest leak we have ever met' all I need to figure out is how to edit it in order, oh well, been a long day!
