Author: Subject: Light cover question
[*] posted on 16-2-08 at 09:42 PM Reply With Quote
I do not have a light cover and not sure what it will do. Is it possible to isolate the light and nitch on a concrete/plaster pool from the water with this device? Would it be useful to determin if a light conduit does or does not leak during bucket test?
[*] posted on 19-2-08 at 08:32 AM Reply With Quote
Hey Hapster!
That light cover is pretty handy just for what you described.
I also used it for main drain test. If you set it up right, you can see air pulling up around the outside of the main drain pipe when you
use a Leek Peeker in the skimmer.
[PHP: 69.9% - SQL: 30.1%]
