Author: Subject: leaks below wood decks
camango
[*] posted on 25-4-06 at 09:02 AM Reply With Quote
what's everyone doing about finding plumbing leaks under wood decks? I hope there's an easier way than pulling up the planks...
and perhaps there's a way to do it with the XLT30?
trying to avoid plunking down a fortune on the helium setup (sorry, lance)
australis
biggrin.gif posted on 15-5-06 at 04:17 AM Reply With Quote
decking solution
bite the bullet and invest in a heluim setup:cool
[*] posted on 6-7-06 at 09:05 AM Reply With Quote
Extension rods
If you have a space between the deck boards you can insert the extension rods that came with the XLT unit. I have successfully located leaking pipes along pool walls by listening at the coping or aluminum extrusion. They both conduct sound very well.
[PHP: 68.1% - SQL: 31.9%]
