Author: Subject: Leakalyzer
[*] posted on 18-7-08 at 12:50 PM Reply With Quote
It should be noted for those unfamiliar with the unit that the two pictures are showing graphs with different scales. The first picture shows a scale of 0-120, the second a scale of 0-30 (4 times the sensitivity). Thus the difference in the slope of the lines is even more dramatic than what it appears to be from your pictures.
Based on your's and Hap's testing we are going to make the following changes to the next units shipped.
1. All tests will be 20 minute tests. As you have noted you still will be able to make determiniations in less than the full length of the test. This will help make the graphs readable and will also help to reduce the Saved test Memory used, (ie one 20 minute test = four 5 minute tests).
2. You will be able to select the desired "Filter Strength" at the set-up of the test based upon your evaluation of the conditions. Higher Filter Strength will slow responsiveness but provide a smoother line.
Hope you agree with these changes. As with any who purchase units this year, software upgrades can be made to your device at no charge if the Handheld portion is shipped back to us.
AquaLeak
[*] posted on 18-7-08 at 04:16 PM Reply With Quote
Lance, good thing you guys were thinking ahead!!!!! I went back to log in the LAD and increased the scale to 120 as you were describing. Here is a new pic, compare these 2 before/after.
http://aqualeaks.com/images/SpaBefore.jpg
http://aqualeaks.com/images/SpaAfter2.jpg
With the scales matching it is much easier to see what the pool did after the patch.
-rob
[PHP: 75.0% - SQL: 25.0%]
