Author: Subject: Log in problems
[*] posted on 6-8-08 at 09:37 AM Reply With Quote
Log in problems
Anyone else having (intermittent) log in problems here??
Sometimes I get right in other times I am not recognized.
Just curious if it's a problem here or with the BBS software!
[*] posted on 6-8-08 at 10:26 AM Reply With Quote
It's a problem on our end.
For now just make sure that below the plugs on this screen it says "Logged in as your name." If you are not logged in here you will have to go back to leaktools.com (click on the back to home icon) log out if you are on the "professionals page" and then log back in.
Don't try to type a message unless it shows you as logged in! Everything you typed will be lost when you try to post. . . . Very frustrating.
This is obviously not the way it should be and I apologize for the duct tape and bailing wire solution for now.
[*] posted on 6-8-08 at 12:47 PM Reply With Quote
Not a problem
"This is obviously not the way it should be and I apologize for the duct tape and bailing wire solution for now"
We use that stuff to fix leaks!!! :D
[*] posted on 17-8-08 at 08:29 PM Reply With Quote
back after vacation
Still have the log in problems... just in case you were wondering..
Love the new liner punches... much better than the old design!
[*] posted on 20-8-08 at 07:42 PM Reply With Quote
Should be fixed now. You may however have to log out of leaktools then log back in one more time to get things re-set. From then on you should be good to go whenever you get to here from the leaktools page.
[*] posted on 24-8-08 at 08:05 AM Reply With Quote
Nope
Still not working for me Lance. I logged out but could not log back in from the message area. I have to go back to the main site then to manage my profile and get into the message area from there!
Keep on trucking!!!
[PHP: 77.2% - SQL: 22.8%]
