Author: Subject: Methods for pressurizing the line with air or gas?
DBCooper
[*] posted on 27-6-06 at 08:20 PM Reply With Quote
Hi,
Ive only used Nitrogen tanks to pressurize the line, what are you all using.
[*] posted on 27-6-06 at 09:37 PM Reply With Quote
I've always used air generated from an air compressor or in some cases a scuba tank
DBCooper
[*] posted on 27-6-06 at 11:59 PM Reply With Quote
Does anyone have any recommendations as far as the type of air compressor that would be suitable?
Id like to try it, but I think it(the compressor) would be very loud, right?
Any info would be greatly appreciated!
[*] posted on 28-6-06 at 11:42 AM Reply With Quote
compressor
Use a compressor with a tank, once tank is full shut off compressor and you will have silence as long as tank lasts
[*] posted on 28-6-06 at 01:32 PM Reply With Quote
33 gallon craftsman
Its mounted in the truck and I have a 250 hose supply reel. With this setup the noise is generally far enough away not to bother me while listening for leaks. I do also have a smaller 4 gallon compressor on board in case the pool is too far away from where I can locate the truck. But you will find that the small compressors will run an awful lot when trying to locate some hard to pinpoint leaks, especially when they are down over 3 feet.
titopools
[*] posted on 25-6-07 at 10:59 PM Reply With Quote
can some one edvice me how to use the XLT 17 to locate the leaks all I hear is a lot of static
[*] posted on 28-6-07 at 07:00 PM Reply With Quote
We use co2. You get more volume than nitro because it is liquid. About $24.
Tank tends to freeze up on bigger leaks.
[PHP: 72.6% - SQL: 27.4%]
