Author: Subject: Leaking steps
[*] posted on 5-7-06 at 09:53 PM Reply With Quote
Leaking steps
Has anyone figured out an easy way to find a leak coming from the steps, instead of dye testing all the screw and seams.
[*] posted on 13-7-06 at 08:05 PM Reply With Quote
Steps
The Leaktracker will pick up a leak in that area. It takes a bit of getting used to the different sound that one may get when scanning this area as the device is very sensitive. BUT, if you get a very STRONG signal on LOW sensitivity there is a pretty good chance you have zzeroed in on the leak.
aquatechdivingservice
[*] posted on 23-7-06 at 07:17 AM Reply With Quote
hydra phones work pretty good too!
[PHP: 72.3% - SQL: 27.7%]
