Author: Subject: tintable putty
[*] posted on 20-1-10 at 09:15 PM Reply With Quote
tintable putty
would anyone know of or be able to share about a tintable putty to match colored plaster ? .thanks
[*] posted on 21-1-10 at 07:35 AM Reply With Quote
Any 2 part epoxy is tintable.
Use gloves and Rit dye you can get at Walmart.
[*] posted on 21-1-10 at 10:12 AM Reply With Quote
thanks side wolf . i came to that conclusion also. i did a little experimentation last nite.about this .
i only have anderson's fast set putty on hand which is solvent based and not water based.
concluded that adding water based food coloring retarded the fast set curing rate and left the cured fast set putty with a rubbery consistency.(also cured in in adish of cold water placed in freezer to simulate a winter time pool)
nice shade of pink though lol;)
[*] posted on 21-1-10 at 10:37 AM Reply With Quote
i think the other kind of putty will work well.
smile.gif posted on 22-1-10 at 11:30 AM Reply With Quote
I have used "Tints-All" for many years to color epoxy, it comes in 1 1/2 oz tubes, limitless colors available, it is available at art supply stores, it is designed for tinting latex, alkyd, oil and acrylic paints, water soluble - washes off hands easily, no gloves needed (Mrs is an artist, she found them for me) it also helps to start with gray or brown epoxy and work towards the final color, I also carry sample pebble tec stones to press into the epoxy surface
Bruce:)
[PHP: 74.4% - SQL: 25.6%]
