Author: Subject: leak trac ,Above ground pools
leakyg
[*] posted on 20-5-10 at 05:44 PM Reply With Quote
hi,
has anyone used the leak trac for above ground pools with vinyl liners. I am wondering if so, the process and how it worked out
thanks
[*] posted on 20-5-10 at 06:50 PM Reply With Quote
It works better on A/G than in-ground pools, rare to have a light or stair molding to deal with, the only problem will be that it is too effective, old thin A/G liners will have many signals from scratches, thin spots and old seams
poolrepairdiver.com;)
leakyg
[*] posted on 21-5-10 at 03:44 PM Reply With Quote
thanks,
do you ground it to the metal on the pool, or still in the ground..
[*] posted on 21-5-10 at 07:04 PM Reply With Quote
I always ground to my copper stake in the ground (all pools A/G and I/G) and soak the stake area with water
poolrepairdiver.com:D
poolchoice
[*] posted on 22-5-10 at 08:33 PM Reply With Quote
ground
How deep is your copper stake. i seem like I have mixed results on getting a ground on above ground pools, although I have tried rebar, pounded about 18" in the ground.
[*] posted on 23-5-10 at 08:35 AM Reply With Quote
Just a 10" spike, the key is wetting the soil.
:cool:
[*] posted on 4-6-10 at 06:01 PM Reply With Quote
:cool:
1oz of dawn dish soap in 5gal. of water will increase the effectiveness of the stake soaking tip, bruce.
i use this in most marginal soils
rwaibel
[*] posted on 28-7-10 at 05:05 AM Reply With Quote
i have always found that I get a getter ground on the pool structure. Above or inground pool. unless it is a polymer wall.
[PHP: 76.4% - SQL: 23.6%]
