Author: Subject: Vinyl liner repair
awld
[*] posted on 24-6-10 at 04:08 AM Reply With Quote
Vinyl liner repair
G'day guys,
I'm having trouble placing patches on vinyl liners at the moment. Water temp is about 8 degrees celcius and the adhesives aren't sticking. I've seen liners where holes have been covered using a 2 pack and you have white spots of epoxy which look crap. I've used the products supplied by Anderson's as well as others and none stick which I'm thinking is water temp. Can anybody offer any suggestions?
[*] posted on 24-6-10 at 06:06 PM Reply With Quote
The problem is not temperature, 8 celcius = 46 f, I have no temperature trouble with patching even near freezing.
The problem is surface preparation, clean and scuff the surface with a Scotchbrite pad, the patch will then stick well, scotchbrite comes in various roughness grades, the green works well without being too abrasive, the pad also works well to collect the glue that squeezes out as you press the patch in place. Always press the patch tight to squeeze out any trapped water and any excess glue.
poolrepairdiver.com:)
[*] posted on 26-6-10 at 04:31 PM Reply With Quote
Bruce is absolutely correct about temperature. I have found the best type of glue is the Boxer type and we get better results if it is used sparingly
snak23
[*] posted on 28-6-10 at 09:25 AM Reply With Quote
Yes, Boxer glue works great. Look for Boxer Vinyl Adhesive #100.
-Mike
Scuba Snak
[*] posted on 29-6-10 at 06:46 AM Reply With Quote
another possibility is try hh64 glue. i use boxer and dont have a problem with it in cold temps. i center the patch and usually put pressure in the center over the hold and squeege (spelling???) the water out of the patch. clean the area with a scotchguard pad to prep the surface. small amounts of unsceen film will prevent the repair from bonding.
awld
[*] posted on 8-7-10 at 05:22 PM Reply With Quote
Thanks guys,
Good info.
Dean
[PHP: 75.8% - SQL: 24.2%]
