Author: Subject: Looking for a Helium detector and pipe knocker
leakyg
[*] posted on 1-7-10 at 09:57 AM Reply With Quote
Looking for a helium detector and a pipe knocker.
Please let me know
tony 610-212-1316
[*] posted on 5-7-10 at 03:52 PM Reply With Quote
U can make ur own pipe "knocker" by buying an adjustable Watts Pressure relief valve and plumbing water backwards through it. By adjusting it you can vary the pitch and frequency to suit the depth of pipe u are looking for.
[*] posted on 27-7-10 at 01:16 PM Reply With Quote
Originally posted by Sdewolfe
U can make ur own pipe "knocker" by buying an adjustable Watts Pressure relief valve and plumbing water backwards through it. By adjusting it you can vary the pitch and frequency to suit the depth of pipe u are looking for. [/quote
hi, would it be safe to assume that you're reverse plumbing the prv or are you using a hose bib connection on both ends ( female in, male out) or are you plumbing to accept the anderson induction/pressure tester?
i've ordered the prv and will be "building" mine this weekend, that's a great tip and i want to thank you for posting it.
jim
[PHP: 68.6% - SQL: 31.4%]
