Author: Subject: how to mark multiple holes to patch
waitedk
[*] posted on 22-10-10 at 02:02 PM Reply With Quote
When you find multiple (small) holes with the leaktrac how do you mark them so you can find and patch when in the water???
[*] posted on 22-10-10 at 04:51 PM Reply With Quote
If they are on a wall or steep slope I use chalk on the coping or deck, if on the bottom or the incline to the bottom I use coins that I marked red with a sharpie and position the coin with the head of the leak trac, I have a handful of very thick coins from trips to Barbados and Honduras that are easy to position. I use the coins when doing underwater inspections as well to mark holes. Customers watching also get a clear idea of what you are finding as your dive/inspection is progressing, makes for good communication and I reward the children (my little helpers) with a coin to keep!
[*] posted on 23-10-10 at 09:40 AM Reply With Quote
I use Pennies or Nickles, they have a square edge and can be moved easier with the probe. If it's on the side you can mark the coping , but still have to rely on remembering the exact location of the hole. When the hole is on a horizontal plane and is a small leak, I try to position the coin directly over the the hole so it's easier to find when I'm in the water.
[*] posted on 7-11-10 at 09:12 AM Reply With Quote
I have successfully marked pool liners with multiple holes using cocktail toothpicks. I just stick them into the hole. The bright coloured ends are easy to spot.
[*] posted on 7-11-10 at 11:37 AM Reply With Quote
Hard to use toothpicks when holes are in deep end and you are on the deck with the Leaktrac. Good idea if you are underwater looking for leaks.
JSPOOLSERVICEINC
[*] posted on 14-11-10 at 02:21 PM Reply With Quote
I HAVE BEEN MARKING ALL HOLES FOUND FROM THE POOL DECK, I USE A CHINA MARKER ATTACHED TO THE PROBE WITH RUBBER BANDS, I DRAW A CIRCLE AROUND THE HOLE,THEN I MAKE THE PATCH BIGGER THAN THE CIRCLE ANDALSO PATCH THE HOLE FROM THE POOL DECK. I USED TO DIVE AND PATCH THE HOLES ,NOW I DO IT FROM THE POOL DECK, HAVENT BEEN IN THE WATER TO PATCH IN AT LEAST 5 YEARS.
MarksPool
[*] posted on 14-11-10 at 06:38 PM Reply With Quote
Okay JS what is your technique for patching from the deck. I have heard of different ways, but yet to find a "foolproof" method.
[*] posted on 15-11-10 at 05:32 PM Reply With Quote
You are right reedpool. WE don't use cocktail toothpicks to mark multiple holes.
Poolleakdetection
[*] posted on 28-6-11 at 08:50 PM Reply With Quote
I use big washers. It is easy to position over the hole and easy to manover using the hole in the center of them.
downunderpools
[*] posted on 29-6-11 at 06:58 PM Reply With Quote
I like to use a china marker. You can pick them up at almost any hardware store.
[PHP: 77.9% - SQL: 22.1%]
