Author: Subject: Skimmer Screws
missingleak
[*] posted on 20-6-11 at 06:50 PM Reply With Quote
Skimmer Screws
What can I use to isolate false readings due to skimmer screws.
I have tried Plumbers Putty and Heavy Plastic Sheet but am still getting ground from skimmer screws. thanks
[*] posted on 22-6-11 at 07:43 AM Reply With Quote
i take it you are using a leak trac to find leaks. Do you dive the pool to find leaks? How do you make repairs.
missingleak
[*] posted on 22-6-11 at 07:53 AM Reply With Quote
Skimmer Screws
Yes I am using the Leak Trac 2200. I do dive every pool after to both repair and inspect all areas of the pool including gaskets etc. and dye test them as well.
[*] posted on 23-6-11 at 09:30 AM Reply With Quote
i just dye test the skimmer screws before i get into the pool. The water is pretty much static prior to entry and thats the best time to test them. I have not found a way to block skimmer or any screws from the leak trac....
[*] posted on 23-6-11 at 09:34 AM Reply With Quote
Most people disregard the readings they get from the skimmer screws after dye testing these areas. Others I have talked to use small suction cups ( the kind that would be used to hang signs on windows) to cover each screw.
missingleak
[*] posted on 23-6-11 at 03:08 PM Reply With Quote
thanks for the help.
[PHP: 73.1% - SQL: 26.9%]
