Author: Subject: Anyone here using the pd-50 portable dive unit?
[*] posted on 24-7-11 at 08:56 AM Reply With Quote
[*] posted on 30-7-11 at 11:19 AM Reply With Quote
We use the earlier one without a tank, wouldn't be without it. If you need to sick a liner patch in the deep end it makes it simple.
[*] posted on 30-7-11 at 04:53 PM Reply With Quote
Thanks! Do you use the tankless one to pressurize lines as well?
[*] posted on 31-7-11 at 07:45 PM Reply With Quote
I don't
Way too much noise. Would never be able to use a listening device. We use High pressure compressed air tanks. Very quiet.
[*] posted on 5-8-11 at 10:59 AM Reply With Quote
Yes we do, you need to keep it as far away as possible and not on a solid deck else you hear the vibration. We also use a radio controlled socket to plug it in to so that its easy to turn off and on when listening without walking back and foreward.
pguthrie
[*] posted on 28-12-11 at 02:14 PM Reply With Quote
I just got my pd-50 a few weeks back and have used it to pressure test, only on residential pools though. I make sure to keep it as far away as I can, but have been successful with it.
I use a higher capacity air tank for commercial testing.
Beards
[*] posted on 25-2-12 at 12:40 PM Reply With Quote
love mine, it is light weight and handy; sure beats hauling steel dive tanks around. I use it for diving and pressure checking. Only problem I have had is that the plastic in line filter connection leaks, it should be made of SS or Brass.
[PHP: 74.8% - SQL: 25.2%]
