Author: Subject: LEAK TRAC PROBLEM
abestpoolsandspas
[*] posted on 22-9-11 at 04:01 PM Reply With Quote
LEAK TRAC PROBLEM
I HAVE AN LT2200 DETECTOR THE RED SIGNAL SENDING LIGHT FLICKERS,IT DID NOT USE TO. ANY SUGGESTIONS ON MY PROBLEMS
THANKS JIM
[*] posted on 22-9-11 at 06:12 PM Reply With Quote
Sounds about right
The red light on my two 2200's each flicker when they are receiving a signal from the detection unit. Seems like the only time they do not flicker is when the battery voltage is beginning to drop off.
[PHP: 68.0% - SQL: 32.0%]
