Author: Subject: Return Testing
Bamapool
[*] posted on 23-12-11 at 07:38 AM Reply With Quote
Return Testing
Morning Pool Professionals !
Question, I have & have had some pools that needed the return/pressure side presure tested for leaks. My problem has been the brains that have built these older pools in the past. Skimmers & the Polaris lines are no problem.
By saying that, I have a return line, with an in-line Hayward style chlorinator and all the PVC connections are butted up, so there is no place to cut the line so it can be plugged off to perform this test. Some of these pools also have all the equipment below the water level, equipment pad is down hill.
Do you test with the chlorinator in tac, assuming it does not leak, or ??
Do you cut the return line somewhere & install ball valves to close off the return side?
I thank you in advance and wish all, the VERY best of the Holidays and a great 2012!
Dean:cool:
[*] posted on 23-12-11 at 10:57 AM Reply With Quote
Initially I would test from the pump through everything back to the returns, after all you don't want a leak anywhere. Just don't overdo the pressure. Pain in the butt with below water level plant as you need to plug pool side if there are no valves to enable any cutting on of valves.
Bamapool
[*] posted on 31-12-11 at 08:00 AM Reply With Quote
Return Pressure
I like the idea of pessure testing on the return side, BUT, I am assuming you are doing so/cutting the return line after the filter/chlorinator OR, are you testing thru these items?
Thanks,
D T
[*] posted on 3-1-12 at 11:47 AM Reply With Quote
Take the connection off the top of the pump and pressure test from there back to the pool, through filter etc.
Bamapool
[*] posted on 3-1-12 at 05:43 PM Reply With Quote
Thank You ! With this being a system with all the equipment well below the water line, all info is most helpful as this once will be a !@#$%^
Dean
[PHP: 73.7% - SQL: 26.3%]
