Author: Subject: How to remove swim jet retainer ring?
sad.gif posted on 7-6-12 at 11:08 AM Reply With Quote
Googled images of swim jets. It looks like they used two Waterway swim jets for fiberglass spas gunited into the pool. The outlet has a retainer ring and is about one inch. I need to pressurize the line behind the outlet and the retainer ring only has 3 tiny nubs sticking out of the inside diameter of the retaining ring.
Looked up all the jet removal tools from Horizon and SPP both out of Arizona.
I called Waterway and talked with their tech service. They were no help.
I also looked for spreading pliers that are adjustable to fit past the large jet nozzle and between it and the retaining ring. No success. Any suggestions?
[*] posted on 7-6-12 at 05:10 PM Reply With Quote
use the correct diameter pvc pipe and notch end to match nubs
[*] posted on 8-6-12 at 10:56 AM Reply With Quote
Thanks, Sdewolfe! I've used that trick in the past, plenty of times. Unfortunately, these little nubs are only about 1mm and they are not facing the front. They are on the inside diameter of the retaining ring. So, any other suggestions by anyone would be welcome. :)
[*] posted on 8-6-12 at 06:03 PM Reply With Quote
if u drained water down you could torch the end of a tool and lightly melt it into the plastic. or just break it
[*] posted on 8-6-12 at 10:21 PM Reply With Quote
That's a good idea about the torch. I used to use that trick when 4000 series Purex fiberglass reinforced plastic filters first came out. They came with a 1/4" plastic nipple that would break off inside the filter. I tried an EZ out the first time it happened and cracked the lid! Then I learned about the heated slot head screwdriver trick.
[*] posted on 8-6-12 at 10:31 PM Reply With Quote
Bought some snap ring reversing pliers with multiple tips today, also. May get lucky with them.
[*] posted on 9-6-12 at 05:23 PM Reply With Quote
any excuse is a good excuse to buy a new tool;)
[*] posted on 11-6-12 at 10:48 AM Reply With Quote
Finally received reply from Warerway:
"Yes that is the Waterway Swim Jet. The front eyeball can be removed by unscrewing the threaded ring behind it but we do not sell any type of wrench for it since the Swim Jet is not designed for gunite but fiberglass or steel walls.
As always, if you have any questions or if I can be of any assistance, please contact me."
It's not their fault, by the way. There is plenty more problems the way that this 2 year old pool/spa combo was built. It's just the tip of the tip of the iceberg.
Brian
QuickLeakCheck.com
aquatechdivingservice
[*] posted on 15-7-13 at 11:28 AM Reply With Quote
expandable plugs work great for these cases!!
[PHP: 78.2% - SQL: 21.8%]
