Author: Subject: Welcome
[*] posted on 9-12-05 at 02:03 PM Reply With Quote
Welcome
Welcome to this new feature of our website. We hope that this means of sharing information with each other will help to make you a more successful and profitable leak detector.
Use this forum to discuss detection and repair techniques, solve difficult leak jobs, compare equipment, . . . or just enjoy the conversation of other leak professionals.
moonlightpools
[*] posted on 17-1-06 at 09:19 AM Reply With Quote
I seem to have a problem finding leaks in liners with pools with steel walls. Is there anything I can do to fix this problem? We also dive pools to find leaks.
LeakGuyRick
[*] posted on 21-3-06 at 10:29 PM Reply With Quote
Moonlight Pools - The steel walls are a source to ground and should provide you with the same results as a polymer pool wall. Make sure that handrails are removed and lights are covered. You may also get readings around your screws. I was just thinking... the above only applies if we are talking about a vinyl pool and you are talking about using an LT 2100 or LT 2200. If you are talking about a steel wall, concrete bottom pool (like a Clayton/Lambert Pool), get out the scuba equipment and get ready to dye test the seams of the panels. Happy Leak Hunting:P
LeakGuyRick
[*] posted on 21-3-06 at 10:33 PM Reply With Quote
Great Site Anderson guys! This is something we can send our customers to find information about their leak prior to us coming out. Hopefully they will realize all of the money in equipment that goes towards quality leak detection.
[PHP: 73.0% - SQL: 27.0%]
