Author: Subject: up date on flood grouting
Beards
biggrin.gif posted on 26-11-12 at 02:27 PM Reply With Quote
Successfully used flood grouting to repair a leak in return line of a gunite spa. on a pressure check, 20 psi to o in about 20 sec. so it was a nice leak, was able to repair without cutting any concrete;)
Previous problem using the material was a manufacturing defect. They left out a key ingredient. Works like a CHAMP.
[*] posted on 30-11-12 at 08:10 PM Reply With Quote
Manufacturing defect??
Hi Beards.
So you had a flood grouting job done?? Did you do it or did you have it done by someone else?
Are you stating that the first time it was done the process failed and then the second time it worked?
Where are you located???
[*] posted on 1-12-12 at 01:43 PM Reply With Quote
Look at Beards 8-12 post for additional info
Beards
[*] posted on 1-12-12 at 02:48 PM Reply With Quote
This was a different job than the one previous post on 8-12
I had factory rep help with this. I am located in Chattanooga, TN
[*] posted on 9-12-12 at 06:43 PM Reply With Quote
Missed that first one!
Didn't see that first post but I did see that you had a 50% (basically) success rate. I would have hoped for better. Did you retry the job that you previously tried (that had the bad mixture) or just did the good old fashioned cut and repair??
Beards
[*] posted on 10-12-12 at 05:47 PM Reply With Quote
Actually, on the first job(the one with the bad product) I made hard repair the old school way-- cut and repair. On the second job with the proper product all went as promised by the fine folks at Floodgrouting.com Had they sent me correct mix on the first job I would be batting a 1.000 . I am sold on this and have another scheduled next week. I will post on how it works. It will not work on every job like a complete separation other than that beats the heck out of cutting out concrete and my customer was happy not to dig into his marble deck.
[*] posted on 13-12-12 at 03:58 PM Reply With Quote
Good to hear
We had about 4+ days invested in two jobs and neither worked. We are going to hit them again in the Spring. Both are main drain issues with nylon fittings and black poly pipe. I have a feeling that each may have a bad nylon fitting.
[*] posted on 14-12-12 at 06:59 PM Reply With Quote
This sounds very promising as a repair option. Does anyone have a good contact from the manufacturer? Thanks, Chris
Beards
[*] posted on 15-12-12 at 09:54 AM Reply With Quote
I can give you manufactures cell # if you want to email me.
stephenhbeard@gmail.com or you could contact them on the web at www.floodgrouting.com
[*] posted on 13-4-13 at 10:08 PM Reply With Quote
Thanks Beards
[PHP: 78.5% - SQL: 21.5%]
