Author: Subject: Flood Grouting
[*] posted on 30-3-13 at 01:12 AM Reply With Quote
Flood Grouting
Hey all, been a while since I've been on here,but I saw an interesting prospect called "flood grouting " that says this product will seal/repair underground plumbing leaks. Was wondering if anyone has had any luck with this or any relative non-invasive products.
Thanks for ANY thoughts,
Chris
[*] posted on 9-6-13 at 12:44 PM Reply With Quote
http://www.floodgrouting.com/
[*] posted on 10-6-13 at 05:38 AM Reply With Quote
Used it twice
Repaired two main drain leaks... both black poly pipe with broken nylon fittings. Works well but it is a time consuming process. A trade off between time and labor I guess.
[*] posted on 15-7-13 at 12:15 PM Reply With Quote
So you like it 4Leakman? I will probably become a dealer here but I have no clue of startup costs. Currently I have 3 jobs this would be useful for, 1 commercial return line, 1 residential main drain and 1 residential fountain return.
[*] posted on 23-7-13 at 06:30 AM Reply With Quote
Hi Pete
Right now the jury is still out. I would not jump into this right away if I were you, especially down there. Your plumbing repairs are fairly easy (comparatively) to what we have up here. If you have to spend a day and a half doing a job vs a half day or so to cut and dig... well, you do the math!
thumbdown.gif posted on 8-8-13 at 06:28 PM Reply With Quote
The jury is in!
Get a Fisher listening device and do the job once!
[PHP: 72.4% - SQL: 27.6%]
