Author: Subject: PVC Pipe repair
[*] posted on 30-3-13 at 01:40 AM Reply With Quote
PVC Pipe repair
Guys and Gals,
Here in Los Angeles there is a product called "Plast-Aid". For all of us that do repairs after locating leaks on plastic pipes, this is a life saver. Those jet leaks that are too close to the bond beam to cut out the venturi tee,plast aid. That leak next to the equipment pad where there is a bundle of 6,7,8 pipes and your leak is on the bottom, plast aid. I've applied this to pvc main line water service pipes running at over 100 psi and have great success. In a pinch I highly recommend it.
[*] posted on 30-3-13 at 03:57 PM Reply With Quote
Its in the store on this site.
Good stuff
[*] posted on 1-4-13 at 07:45 AM Reply With Quote
Excellent
I have used it even underwater to make repairs to fiberglass / plastic steps
[PHP: 72.5% - SQL: 27.5%]
