Author: Subject: Pressure testing step return
[*] posted on 28-6-07 at 08:28 PM Reply With Quote
Any advice on pressure testing returns in steps or buddy seats that have a air valve. No matter how closed the valve is, when you add water, it comes out through that valve(loss of pressure). I have almost all sizes of plugs, none will properly seal these valve. Any idea's.
Dave
[*] posted on 2-7-07 at 09:16 AM Reply With Quote
plugs
try an inflatable plug; sometimes down 1 1/2" lines past air lines; sometimes down air lines,, some times both.
mercy2104
sad.gif posted on 26-9-07 at 06:27 PM Reply With Quote
Test Return Line
Test Return Lines: The situation is after I put all plugs-closed in the jets of pool. Where I do or Where I put the pressure tester or I need to have any cut after filter's plumbing.
[PHP: 71.1% - SQL: 28.9%]
