Author: Subject: glue joint leak
Jacuzzibob
[*] posted on 28-9-10 at 08:05 AM Reply With Quote
glue joint leak
Hi All, New Guy here. Need recomendation on which Anderson product would be best used for a 2" flex/pvc coupl glue joint leak on pressure side. Leak is a dampness static/ drip per second or two w/pump on high. Thanks for your response.......... BOB
[*] posted on 28-9-10 at 09:01 AM Reply With Quote
try the h20 glue
[*] posted on 29-9-10 at 09:16 AM Reply With Quote
pull it apart glue it properly, after cleaning thoroughly.
hinejs
[*] posted on 18-11-10 at 09:29 PM Reply With Quote
Man, we tried teh h20 glue today on a jet & 3/4 flex hose connection. Couldnt stop the leak w/ the line wet. We decided to drain the tub below the line, apply the glue, let it setup a bit till quite tacky and then let it set for another hour. We didnt wait around for the net hour, but we're heading back to check it out tomorrow.
-Jeremy
Florida Leisure Pool & Spa
www.FLLeisure.com
Originally posted by trackerm
try the h20 glue
www.FLLeisure.comwww.FLLeisure.comhttp://
[PHP: 70.4% - SQL: 29.6%]
